RF30 spindle brake
martik777
Apr 19, 2011
572
How do you think this works? It appears the lever to actuate it is attached to a shaft below the red bolt but how is it locked in the brake position.
darkzero
Global Moderator
Staff member
Nov 27, 2012
4,160
Can't see the pics as a guest.
darkzero
Global Moderator
Staff member
Nov 27, 2012
4,160
I don't think it actually locks, just brake. If it does lock I can't tell where the latching mechanism is in those pics.
martik777
Apr 19, 2011
572
Some kind of cam arrangement is my guess, that pawl and notch circled in red maybe?
darkzero
Global Moderator
Staff member
Nov 27, 2012
4,160
I thought that notch would have been part of the latch mechanism to lock if anything but couldn't see how it worked. Now that I thought about it some more, maybe it's similar to a BP. Like you pull down & push up to make the triangular key lock in & out of the notches? I can't really tell if the lever can do that though.
derf
Brass
Oct 3, 2015
810
Look at the first pic.....the screw that holds the top link on is off center to create an eccentric. The triangular block engages into the notch when flipped the opposite way to hold it open, not closed.
Superburban
Jan 2, 2016
1,043
It looks like it is using an overcenter lock design, real similar to how many box and cabinet latches
The lower piece likely piviots where the red circle is. rotating it clockwise, brings the upper pivot (green arrow) past the center of the line from where the lever pivots on the right, and where it pivots just below the red circle, ending up approximately where the green circle is. The spring is then trying to pull the lower piece further clockwise, but is prevented by the part (where the red arrow is pointing) that mates into the cutout (yellow arrow)on the arm.
pontiac428
Mo-Max
Apr 23, 2018
905
That's an ambitious modification. I think the RF-30 needs a spindle lock for sure; a spindle brake maybe not so much. It's a heck of a lot better than relying on my bad habit of grabbing a handful of belt while loosening the draw bar. Would make locking and unlocking keyless chucks easier, too. Thanks for sharing the idea!
martik777
Apr 19, 2011
572
I want it to eliminate using 2 wrenches on my ER25 collet chuck. Not sure if it will apply enough braking force.
