Can anyone tell me more about this surface grinder and whether, if it’s in good shape, it would be a reasonable way to add surface grinding to my shop?
Mine must be a lot older, a little different layout of the controls. Mine can make thinks flat but too much play in the table from wear even for the gibbs adj. But it cost nothing after selling the unrelated items that came with it
From all the stuff I’ve read on it’s more of a tool grinder than a surface grinder. It is kinda light with a lot of overhang so prone to chatter. If you notice most surface grinders do not use this type of configuration.
Appears you have the Univise and/or Unihead accessory sitting on the top shelf with some other goodies.
What all is up there and are they included?
You don't have the universal table on the machine so cutter sharpening will be somewhat limited.
This is all very helpful thanks. I think this will be a useful tool for me. I’m looking forward to learning about it. It does come with all the former owner’s tooling so we will see how it ends up.
