- Nov 14, 2016
- 3,041
Some of the discussions on 3 in 1 machines has had this bouncing around in my head. Not at all a jab at combo machines, they are just the inspiration for the question.
Obviously if you have specific jobs in mind then you can just pick machines that are sized for the needed work, but in the case of setting up a generalist shop how would you match up a lathe and mill? No cheating and say buy the biggest of each that you can find.
Perhaps I'm biased coming from mini-machines, but at the small end it seems the obvious intended parings place the mill at slightly larger capacity than the lathe so anything you can work on the lathe will probably fit on the mill with some room to spare. This makes sense to me, but it is also possibly explained as simply as maybe it is possible to make a functional lathe of a smaller size than you can a functional mill.
Now when you look at the 3 in ones, you typically see a 12-14" swing lathe, with a relatively small mill, sometimes a mill that alone would be considered in the mini class, and even if not still definitely on the smaller end of the scale.
To me this makes about as much sense to me as matching a Grizzly 7x14 lathe with a Bridgeport mill. Sure there are some that this will work, for but I think most would find the lathe lacking in this case.
So back to my question, if you were starting from scratch how would you match a lathe with a mill? By size, not brand specific.
