I purchased a gallon of synkool, but before pouring it my bandsaw reservoir I needed some assist.
Instructions indicate mixing with "clean water" 25:1, I believe, for my purpose. It also said beware of freezing.
That leads me to some questions not answered on the jug.
1. What exactly do they mean by "Freezing." ? Does freezing mean that the chemical structure of the fluid changes in an undesirable way or does it mean just a caution that it will expand and possibly damage whatever it is inside of?
2. The next question relates to the first. Instead of tap water, can I mix rustlick with windshield washer fluid (I have a bunch), to stop the contents from freezing?
3. Is there anything else I should mix in not mentioned?
4. The 7x12 HF bandsaw instructions say to remove the coolant from the tank when there's too much metal debris in the fluid. However, they didn't provide a test for that so how do you know when there's too much? Do you just notice that the coolent comes out too slow or too little?
Thanks!
Thanks!
