- Sep 22, 2018
- 23
I'm pretty much a newbie with my PM-1228. I'm the 3rd owner of this tool but it's in very good condition. My issue is with the jerky manual movement of my saddle. I see videos of people using various lathes and see them traversing their saddle easily and smoothly, oftimes one-handed. I also see people turning a diameter manually (not powerfeed) very smooth and with control. I can't seem to do that on my machine. When I move the saddle to the tailstock to get it out of the way it can be moved quickly with a bit of resistance on the handwheel using two hands; however, if I would want to turn down a cylinder diameter manually, the carriage has enough sticky friction (stiction) that it hops its way along.
I've lubricated the saddle via the oilers and brushed on the tops and bottoms of the ways. It helps a bit but it still doesn't move smoothly and easily enough that I could get an even and consistent feed rate. I'm using Mobil Synthetic lubricant, 75W-90 as my way oil.
I've checked all of the gibs and have even tried it with the gibs way too loose. Still not smooth and easy.
Are my expectations too high? The only way to turn a smooth even-fed cylinder is via the powerfeed OR the compound.
Is there an adjustment I'm missing?
Is the Mobil 75W-90 not a good choice for way lube?
thanks.
steve
thanks.
steve
