- Feb 1, 2015
- 9,608
I just watched your video and I feel your frustration. I hadn't realized that you had to go up steps as well. One suggestion would be to place your levers under the plywood and lift the opposite end up to lay your plywood a a more shallow angle which will reduce the force need to pull it up. If you get it high enough to place a garage jack under it, you could jack the plywood to horizontal. You could also slide the plate of your dolly under the plywood to lift. Keep in mind the the effort you are exerting to go up the steps is the amount of restraint you will need to control the plate going down. Should you decide to go your current route and you are concerned about damaging your floor, put a sheet of plywood down to distribute the weight better. Again, good luck!
