Hi all, I am trying to remove the underdrive assembly because there is a lot of wear in the cone pulley shaft. The lathe is from 1939 so the design is slightly different than the videos or info i've been able to find. It uses plain bearings that you oil instead of ball bearings of the "newer" designs. I'm trying to remove the shaft that holds everything in, part 2548 in the parts catalogue. (same design but the 11" only has 3 pulleys instead of 4 for the 13" or 16")
It should only be held in by a set screw, but I am unable to fully remove the set screw. I can rotate the set screw about 200 degrees, but something binds up and it wont turn more. I've tried removing the paint, dremeling back the top if the threads got damaged somehow, I've tried an impact gun, wrench on a screw driver. Something just doesn't add up because I can't think of a reason why it would rotate 200 degrees but is not able to come out. Any ideas appreciated. The shaft is loose, i am able to rotate it and move it back and forth about 1/4" so that isnt the issue.
View attachment VID_20201231_192333216.mp4
