- Jul 13, 2014
- 1,051
I am back in the garage after total knee replacement starting to do some more work on the SBL 13. One small item I need to correct is the movement of the TS spindle, it rotates ever so slightly. I pulled the spindle out hoping to get the keyway out and maybe duplicate it, trying to pry the keyway it would not budge. Did not want to do any more digging in taking the risk of gouging the bore.
Is there a pin holding the keyway in? Could not see anything on the outside, the TS has been heavily repainted over the years, if a pin or screw is there, it has been covered up.
Thank you.
Thank you.
