There is no torque to my knowledge. When adjusting the spindle bearings install a lever in the spindle with an indicator on the spindle and lift to see how much play there is. The adjustments come from adding or removing shims. TAKE THE EXPANDER SCREWS OUT BEFORE YOU TAKE THE CAPS OFF
Do a search for bolt torque and use the generic chart that goes by bolt size. You can also find it in most auto service manuals like Haynes or Chilton. Thats what I do for unknowns anyway.
