- Dec 18, 2019
- 6,623
So I've been using a 3" toolmakers screwless vise for a while. Every so often, I'd say once every 2 months or so the screw strips. This has happened 3 times now. I've been using grade 12.9 screws, sourced from McMaster, so they shouldn't be junk. (But they are all from the same lot.) The nut in the vise seems to be fine. Is this just what happens? I'd rather the screw strip than the nut, but what's going on? Using a short allen wrench (under 3") on the M8x40 screw, so it's really not possible to reef down on the screw. When it happens, the vise appears to tighten then it gets loose. That's when the threads yield. Any ideas? What would happen if the screw was slightly too long? The strip point is near the top of the nut, I think.
I don't know where the first screw is, but it failed the same way.
And why on earth is this kind of vise called a screwless vise! Those things above look like they were screws once!
