Not many of of these tools are often used in modern machine shops today for routine work, fabrication (and inspection) are a completely different matter however. Why would you blue and scribe a bolt pattern on a mill part when one could just walk it with a DRO?Looking for recommendations for tools & supplies for laying out a job like compass, scribe, blueing, etc.
Didn't find any article/posts after quite a few searches.
Any links or recommendations for searching ?
I often lay out work just so that I can see what I am doing and so reduce the risk of silly errors. I use magic marker for blueing.Not many of of these tools are often used in modern machine shops today for routine work, fabrication (and inspection) are a completely different matter however. Why would you blue and scribe a bolt pattern on a mill part when one could just walk it with a DRO?
I sometimes scribe heavy lathe parts for length when the tolerances are within scribing accuracy, say 1/32nd, on a 60" part, removing the part from the lathe setup to measure becomes impractial, not to mention the time required setting up a 60" dial/vernier caliper, gathering and stringing together gauge rods, clearing the accumulated junk off of the surface plate Etc. We have a 48 X 96 X 24 granite surface plate.
Figured dying and scribing would allow hogging out material without stopping every few passes to measure, measure, and measure again.
As an inexperienced hobby guy, thought it might help from making mistakes and wasting a lot of material.
