Got this 16 x 36 Sebastian lathe from a friend. His father bought it to use in retirement and never set it up. It is 3 phase and I have the converter sitting in the floor ready. Lathe has been in an old shop for 25 years or so. Good bit of surface rust on ways. The cross slide screw is bent. Maybe I can straighten it enough. The dovetail in the cross slide is about 1/2 inch too wide. Seems to be missing a spacer dovetail from the slide. Also 2 of the 3 chuck tightening screws are missing the worm gear. Wondering whether to use oil and steel wool on ways or derusto and scotchbrite. Good winter project if I can get it in the shop. Took it to the Coop scale and it weighs 2200 lbs. Also need to change the gearbox oil. Without a manual I am thinking 30 wt non detergent motor oil if I can still find it.
