I assumed that was the case but unfortunately didn't find one. I have a Logan 9" tailstock but not looking to part with it as it's a part of my Logan 9" lathe, which I use regularly. I assume most would be in the same boat.I'm looking for a complete tailstock.
If you can only buy half of one, the half in the ebay listing is the better half to have. The bottom half would be easier to make. If you end up going that direction I would be willing to provide dimensions for the lower half.
Sure thing. I will grab those dimensions next time I'm in the shop. If you don't hear from me in the next 3 days or so it means I forgot (and I won't be offended by a reminder).Strantor, thanks for the offer. The problem is that I don't have access to a mill. I would appreciate the dimensions of the bottom plate in that I might get lucky and find someone with a mill willing to make it. Thank You
Okay. Reason I mentioned calling him is that not everything is listed on his website. But if you call, he might have it (new or used).I've inquired at Logan Lathes, Ebay and most other obvious avenues. No luck except parts and not all parts necessary for a complete tailstock.
