Somewhere in this period of time I picked up a 56C 1 hp tefc 1750 rpm 3 phase motor and then purchased a vfd to team it up with.
However, it turned out that the C-face motor frame doesn't really fit on the mill that well as the c-face end bell hits the belt guard.
I'm not sure if I have a picture of it installed. I keep looking. Because motor hits belt guard, you have very little movement or swing on motor to swap belts.
I then picked up a metric M80 1 hp 1740 rpm motor for a decent price, but again it doesn't really fit that well either as the motor mount plate isn't wide enough to accommodate an M80 base, so some kind of adapter plate will probably need to be made. Additionally, the mills pulley needs to be bored out to 19 mm, which I did't want to do as there is no turning back. One also needs a metric keyway broach to complete the job, or 3/16" broach, neither of which I have, and make a step key. Step pulleys with 3/4" bores are available on the net, however I've never found one with the wider belt grooves, ie 5L. Would still need a step key. I concluded that the money for the step pulley would be better spent on the appropriate motor.
I said to self, a 2 hp motor would really be nice, so what would it take to get there? $290 all in for a Dayton 56H frame 2 hp tefc 1750 rpm 3 phase motor. So, this one is a nema premium rated motor, apparently all nema premium motors are VFD compatible. Taking motor apart, it looks to be made by Weg.
After seeing how the 56C motor hit the belt guard, I spent many hours researching what would or wouldn't fit.
To be continued.
