- Feb 7, 2013
- 2,489
Hello all,
A project I am considering involves cutting two six foot key ways in a 6 foot piece of one inch cold roll rod. The key ways are 180 degrees apart if that matters.
This will be done on my vertical mill with an end mill OR by using a horizontal mill attachment on the same mill. It is unclear which method would be
better. I have done this in the past using an end mill and it can be done but quite time consuming. I can deal with the repeated set up part but wondering
if the horizontal mill attachment is up to the job or if it would be too much for it. I have the unit that uses an arbor and mounts to the ram ways on the mill.
The key way cutter I have for the horizontal attachment is about 4 inches in diameter by 1/4 inch. I tried using it once in the past and it just seemed to
cut too hard. The cutter appears sharp but not cutting well used with the horizontal attachment. I'm not sure if the problem might be the cutter or if
the horizontal attachment lacks the rigidity for the job. I would like to try the horizontal milling method but don't want to set it all up twice and end up
using the mill vertical with a 1/4 inch end mill. The mill I will use for this job is a standard 9x42 knee mill. Maybe someone here has experience using
the horizontal attachment of this type. The rod will be affixed directly to the mill table with clamps.
Here are my questions:
1. Would the horizontal attachment be up to a job like this? ( using angle attachment, arbor and ram support)
2. If I try the horizontal method, what depth of cut would be reasonable for each pass?
Thanks everyone.
Thanks everyone.
