Very well said. Oil is very hard to burn. Only vapor does, which takes time to release. as long as lots of regular air is in there, it's hard to burn.I worked in a machine shop and we weld patched gasoline tankers on the inside so as not mar the outside. We would blow down the tankers with blowers as too rich or too lean fumes will not ignite. Much safer to make it too lean. The shop welded gasoline tanks all the time with this method also. It doesn't take much pressure just volume. I needed to weld in some spigots on some jerry cans and used a leaf blower to blow out the cans, worked well but when you first strike that arc you kinda tense up. Properly blown down I have never heard of a problem but I have heard of plenty of instances of filling with water and having a bad outcome. Your experience may vary so safety first.
