I have an older G&E shaper and the down feed on the head is extremely tight and I cant figure out why, the gib is loose and its still is hard to move, the screw seems to go freely as well. Anyone have any helpful insight on this issue? Thanks
I have already taken it apart and nothing seems to be wrong, no burs, scratches, dents, or rub marks that I can seeI have a G&E shaper. I don't have an answer, but you may have to tear it down and go exploring for the problem.
I wrote a response asking if there was any galling, swarf, dirt etc. without realizing you already checked for those things. Does the screw and nut move smoothly if you disconnect/remove them from the shaper? Seems to me that would be the
ill have to check that thanksmost likely issue if everything else looks to be ok.
I will also look into this, Thanks! I have a older model than that but I assume the looseness is similar.I found these for you too: The gib should be loose so the tool slide hangs on the nut, looser then what you would have on a lathe compound.
