- Jun 27, 2016
- 378
A question on the spring loaded work head stop, with the stop engaged, is it supposed to stop at 90 degree intervals? Mine goes past that amount by a fair amount.
If it’s like my Checkel the degree bezel can be adjusted to inner stops. Might try finding the stops that are 90deg and adjusting you bezel to that. Sorry if that’s not clear or the right nomenclature, I’m sick bed with the worst flu in decades.A question on the spring loaded work head stop, with the stop engaged, is it supposed to stop at 90 degree intervals? Mine goes past that amount by a fair amount.
get well soon sirIf it’s like my Checkel the degree bezel can be adjusted to inner stops. Might try finding the stops that are 90deg and adjusting you bezel to that. Sorry if that’s not clear or the right nomenclature, I’m sick bed with the worst flu in decades.
Sorry to hear that you have the flu, I just over my second round of covid! Maybe I didn't explain myself correctly, I am talking about the hard stops, not the adjustable bezel. Mine has more than 90 degrees of swing before hitting the stops, probably like 5-10 degrees past in both directions.If it’s like my Checkel the degree bezel can be adjusted to inner stops. Might try finding the stops that are 90deg and adjusting you bezel to that. Sorry if that’s not clear or the right nomenclature, I’m sick bed with the worst flu in decades.
I thought I was addressing it. Find the hard stops that are 90’s and adjust the bezel to it. The hard stops are not adjustable and are hidden, and my bezel didn’t come adjusted to the hard stops. I hope that make more sense.Sorry to hear that you have the flu, I just over my second round of covid! Maybe I didn't explain myself correctly, I am talking about the hard stops, not the adjustable bezel. Mine has more than 90 degrees of swing before hitting the stops, probably like 5-10 degrees past in both directions.
