[4]
Shop First Aid Kit
[3]
[10] Like what you see?
MozamPete
H-M Supporter - Gold Member
Jun 26, 2014
593
What do people keep in their shop first aid kit?
I work in my home workshop alone most of the time and realize there is a lot of opertunity for things to go pretty bad, pretty quickly. I have several fire estingushers, l’m wiring emergency stops into my machines as I update the control, but I don’t actually even have a box of bandaids in the shop (the first aid kit is in the house).
So I figure I should equip a workshop specific first aid kit. I’m thinking field dressing for major cuts, and especially things you can apply yourself if needed, eye wash, something for burns, etc
What do others have/suggest?
David S
Nov 18, 2012
1,327
My workshop is in the basement of the house so not too far away from first aid stuff. The only thing I have in the shop are band aids. Sometimes no matter how hard I try to avoid getting cut, I sometimes get a splinter or get a small nick that bleeds like crazy.
I always wear full safety glasses in the shop, with face shield if grinding. I don't use much in the way of chemicals, however just outside the door in the laundry area I have a flexible hose on the laundry tubs that could be used for eye wash.
It sounds like you are already doing a lot of preventive things and I would encourage everyone to think of what could go wrong before they approach doing things they haven't done before.
David
brav65
Sep 24, 2014
925
I would think of a major catastrophe that would require a tourniquet, an Israeli pressure bandage, celoc...etc. for a little cut I would want to go in the house and clean it well. I carry an edc bag with all of those things plus some bandaids, Tylenol etc. that bag goes everywhere with me. Everyone laughs at my murse (man purse) but I have used it so many times I could not even count.
Billh50
Jan 26, 2015
1,922
Since I am close to the emergency stuff, the only things I keep in the shop area are a clean rag to throw over those nasty cuts, bandaids and super glue. The clean rag is only so I don't leave a blood trail through the house. The wife tends to get upset when she see a trail of blood. I don't know why.
CluelessNewB
Active Resistor
Mar 3, 2013
1,202
Paper towels and electrical tape for minor cuts! Keeping some of the clotting sponges around might be prudent for a serious injury. Phone to call 911.
kvt
Oct 21, 2014
2,072
shop, the paper shop towels and tape, in the house most other stuff, including surgical super glue. Most times just using the tape etc works better than a banband does. but normally will go into the house and wash it out then bandage it up as needed. Have a skin condition and have to patch splits etc all the time.
mikey
H-M Platinum Supporter ($50)
Dec 20, 2012
5,410
The number 1 emergency piece of kit for those of us (probably most of us) who work alone in our shops is a cell phone. If something catastrophic happens you are not going to be handling it by yourself. Call 911, grab something to soak up blood and apply pressure to the wound until help arrives. Sit down on the floor because if its bad enough to call 911, there is a good chance you're going into shock soon.
The best "kits" I've seen come from these guys: https://mymedic.us/collections/first-aid-kits. Lots of kits available. I suggest you choose based on your level of competence; it does no good if you don't know how to use something, even if it is there. This especially applies to a tourniquet. If you ever use a first aid kit, replace any item you used as soon as possible.
The vast majority of injuries in the shop are minor ones - cut, scratch, small burn, splinter, etc. These are injuries that can be treated by you, with one hand.
  • Time: as soon as an injury occurs you need to stop what you're doing and treat it, now. Don't slap a band aid on it and get to it later; that invites infection. If you treat a wound effectively within the first few minutes the risk of infection is greatly reduced.
  • Help: if it is anything more than a truly minor injury, get someone to help you. At this level of injury you are not going to be thinking clearly - get help. If no help is available and its something you aren't absolutely sure you can manage, call 911.
  • Soap and water: this is the best way to clean and flush a wound, and it is better than alcohol or Betadine when it comes to wound healing.
  • Alcohol and Betadine swabs are good to have. They disinfect and sterilize a wound and the area around it when you cannot get to soap and water. You cannot effectively flush a wound with these but for minor cuts or scratches, they work. Clean the wound and at least several inches around the wound.
  • Triple Antibiotic Ointment: get it at the drug store and replace annually. Apply with a Q-tip, not your grubby fingers that are full of bacteria.
  • Band Aids: get the waterproof, fabric type. The others are a waste of money for a shop guy.
  • Paper Tape: 3M Micropore tape is one of the best tapes to have. It will hold on a dressing and can be used in place of a band aid. It passes air and water but will not allow bacteria to pass. You have to clean the wound, stop the bleeding, clean again and then apply the tape and allow it to heal under the tape. Works good, especially for skin avulsions where you scrape off some skin but its still hanging on. Clean gently, push the flap of skin back into place, apply some antibiotic ointment and put a piece of paper tape over it. If you leave the tape in place until it heals, you may not be able to see where the wound was unless you really look for it.
  • 4X4, 2X2 gauze pads: good for cleaning up blood, for applying pressure to a wound and for dressing a wound.
  • Stretchy self-adhering tape: better than regular tape to hold a dressing in place.
  • Splinter removal kit, Optivisor so you can see that damned thing.
One of the best first aid items is a good book on first aid, preferably read before you need it. Watch for any signs of infection - redness, heat, pus - you're a guy, you know what an infection looks like. If you see it, go to the doctor.
F
f350ca
Guest - Please Register!
I think the people designing the wrappers for band aids have a really really sick scene of humour. Just try and open that hermetically sealed, stuck with Gorrila glue wrapper with one hand and maybe a couple of fingers of the dripping hand, while your leaking all over the shop.
Greg
Silverbullet
Gold
May 4, 2015
3,454
I've always kept first aid kits everywhere, my shop and house have large sets. Each vehicle has a small set up. I've had some nasty cuts and punctures , burns are almost a weekly thing . I keep antibiotic ointment , ace bandages , bandaids , tweezers , even scalpels until used . Peroxide and alcohol are a must . Finger cots , and the stick on cut sutures for nasty deep cuts.
C
cg285
masking tape, duct tape if the masking tape doesn't work, oil dry for the blood spots on the concrete
scribe or razor blade for the metal splinters
agfrvf
Active Member
Mar 13, 2017
167
Electrical tape works well when you spring a leak on a finger.
Aaron_W
Nov 14, 2016
494
First aid kits are great, but they do little good if you don't know what to do with it. If you have some how made it this far in your life without formal training, or if it was 15+ years ago in high school then get yourself into a first aid and CPR class. They are fairly inexpensive and can literally save a life.
Things change, cutting edge medical treatment 20 years ago has in some cases become available to the individual. Techniques that were thrown out in years past (I'm thinking tourniquets in particular) have come back in favor. Others taught in the past (inducing vomiting with syrup of ipecac) have been found less than helpful in the home setting.
A very basic class is about 4 hours, more advanced might run 8 and you can get the basic level of training required of first responders with a 3-4 day commitment. I will always steer people towards a real live person instructing and providing hands on practice, but there are plenty of basic classes available online. I've even seen an online class for first aid for cats and dogs (treating them, not teaching them :) ).
Hopefully it would never be needed, but particularly for those with larger machines capable of causing massive injury not a bad addition. As people age the bodies ability to control bleeding can be impaired as well. An injury a healthy young person might shake off could be lethal to an older person or one taking medications that might impair bleeding control (blood thinners etc).
Not trying to be funny or gross, but a few quart or gallon ziplock bags could also be helpful for collecting bits removed by a machine were a serious human to machine contact to occur and remove parts you are fond of.
Groundhog
Jan 20, 2016
989
I should probably do better but I keep a box of band-aids and a bottle of skin super glue in my toolbox. The super glue doesn't work until the bleeding stops though - so yeah, electrical tape. Man, I have different grades and different colors of that!
Shootymacshootface
Active Member
Mar 17, 2018
352
I knew (deceased) a logger that worked alone much of the time, and his first aid kit was a turniquit, a roll of duct tape, and some maxi pads.
kvt
Oct 21, 2014
2,072
a clot stick, or clot powder both work to help stop the bleed so you can use the super glue. But sting. If in hurry and not bleeding to bad, Electrical tape all over the place. My father taught me that one.
Groundhog
Jan 20, 2016
989
kvt, I forgot about that stuff. I use a styptic pencil for shaving cuts and it stings like he**. I can only use it in the mornings before I'm awake enough to realize what I'm about to do!
Charles Spencer
Aug 29, 2013
1,047
Firstly, yes a cell phone. It's always in my pocket when I'm in my shop. For serious injuries it's good to have a professional available. In the shop I keep some tape, clean paper towels, band-aids and wet wipes in an old tobacco can. My shop is in my basement so I can access my home first aid kit easily. It's in a small backpack and I assembled it based on the old Army combat lifesaver bag. (I can't reasonably get everything in the newest version.) I've taken the 40-hour combat lifesaver course twice. Also a copy of FM 4-25.11 First Aid. You can get it from Amazon for $10. Or you can download it here:
https://archive.org/details/FM4-25.11
And I try to remember to inventory my first aid kit twice a year. This is a copy of the checklist that I use:
First Aid Kit As of:_____________________________
1 FM 4-25.11 (December 2002)
1 7.25" Surgical Scissors
1 Pocket knife with spatula
1 TK4 Tourniquet
1 Nasopharyngeal Airway size 28 Fr (9.3 mm/0.37")
1 Wash cloth
2 pair disposable gloves
1 Cravat dressing - Army (37" x 37" x 52") (NSN: 6510-00-201-1755)
5 Pressure Dressings - Army (NSN: 6510-00-159-4883)
4 Compress and bandage - Army (2" x 2") (NSN: 6510-00-200-3075)
12 Butterfly sutures
1 Roll gauze (4.5" x 3 yards)
1 Roll gauze (3" x 6 yards)
2 Gauze pad (8" x 4")
4 Gauze pad (2" x 2")
1 Roll surgical tape (2")
1 Roll surgical tape (1/2")
1 Iodine bottle (2 oz.) Expires 07-18
2 Cold packs
1 Ace type bandage (2" x 36")
1 Band-Aid (bundle)
1 Q-Tips (bundle)
1 Antibiotic Ointment (1 oz.)
10 Ammonia Inhalation Ampules
1 Field Splint, SAM, 36"x4.5" (NSN: 6515-01-225-4681)
1 Flashlight
_ _______________
_ _______________
_ _______________
_ _______________
Or, to quote Bill Murray, 'ARMY TRAINING, SIR".
(I got most of the Army dressings off ebay.)
Suzuki4evr
Brass
Sep 29, 2017
632
Electrical tape works great for those little cuts that think they are big gashes and won't stop bleeding.
kvt
Oct 21, 2014
2,072
Groundhog, yea, you may say a few words when you get a cut, but put the clot stuff/septic pencil on and you will be saying a lot of bad words real fast. But it works. have only done that one time, Should have probably gone to the doctor but needed to finish a job so did what I had to. (and did not like doctors and still don't)
Eddyde
Bronze
Oct 13, 2014
1,487
Preparation is good and prudent but in my experience when a serious injury occurs, people tend to grab what's readily available.
When my friend blew his finger off with an M-80, I used my shirt.
When my business partner sliced off the side of his finger on the bandsaw one of our employees grabbed a stack of C-fold towels from the bathroom dispenser, despite there being a fully stocked first aid cabinet right next to it.
And when my fingers collided with a panel saw blade, my shirt (a different one) was again the bandage of choice, and yeah, the aforementioned first aid cabinet was close by....
HarryJM
Mar 16, 2015
138
My shop/shed is about 75' out the back door of our house and I have been thinking about a hands free communications system with my wife and the voice activated Amazon Echo Dot may be a good solution.
[6]
[5] [7]
