Bob,
Good post, but you should find that just keeping it in the film container will be plenty good enough.
I mixed mine up a couple of years ago, and if it starts to dry up a bit, I just put a couple more drops of water into it and give it a good stir, the same if I want to put a bit more flux in, half a teaspoon of flux and a dribble of water soon gets it to the consistency of pouring cream.
BTW, I use the Tenacity range of fluxes, #5 is the latest and best. Designed for silver soldering stainless steel with cadmium free solder, but over the years, I have found it is great for everything, the flux carries on working well past the temperature ranges where others have given up and stopped working.
I'm sorry, but I don't know if the lads in the US can get such stuff in their country, but for the UK, it can be obtained from almost any good model engineering supplier. Go down the page a bit on here, and you will find it. A 250g tub should almost last a lifetime, it will do for me, and I do a fair amount of silver soldering.
http://www.chronos.ltd.uk/acatalog/Engineering_Menu_Silver_Solder___Fluxes_347.html
John
John
