- Apr 6, 2011
- 2,082
I have some offset holes to drill in some SS disks that I've made for a project. I've got the pieces blued and a very nice, accurate little "X" where the holes should be. It's just a simple drill press and I don't have an X-Y table on it so I needed a way to center the drill bit on my "X"s.
Grabbed a coffee can and pulled out a socket head bolt that looked stainless (mystery metal), threw it on the bandsaw and cut the head off. I then chucked it up in the lathe and faced where the "head" used to be. That end was then put into the chuck. I reset my slide and compound and proceeded to cut a taper using only the compound. First time doing that! I think it came out fairy well.
To give you some idea of scale, it's sitting on a standard size stack of post-it notes. I figure that I can put this in the drill press chuck and position the work underneath it. Once I have the work secured swap it out with a center drill and I'm on my way to making holes.
I'm still open for suggestions if there's a better way do get it done though.
-Ron
-Ron
