- Feb 7, 2013
- 2,498
I do some gas welding and lately the oxygen regulator has been a little flaky. It came to a head when I installed a new oxygen tank and
the regulator was releasing gas out of the holes in the regulator itself! The welding shop will send them out for refurbishment for a fee
and you are back in business but I decided to have a look at it myself. I'm using a Victor SR250C regulator.
The welding shop said there is a lot in there and my thought was:" How much could be in there?" I had to know so found out there is a diaphragm, washer
and spring to start with.
Under the brass hex were a few small parts. I found that there is a repair kit one can order for about $20 which consists of the diaphragm and the small inner parts.
Below is a photo of the small parts. One might think that the problem is the white washer but such is not the case. The new washer is the same way.
I suspect that the seal in the little brass part (second part from the left) is bad. I will take it apart eventually and have a look inside but have the kit on the way
so it is a relatively simple matter to install the new parts and reassemble, a simple five minute job. The Victor set has served me well so I feel it is better
to restore it to functionality than buy a throw away unit on E-Bay. Hopefully someone will find this interesting. I did.
It's amazing how much I use my gas welder and had to use my TIG machine to finish up the job I was working on. I need to do more TIG welding
as I'm a little rusty at it. It got the job done though so all is well that ends well. Have a good day out there in machinist land.
