I am trying to separate a turbo charger from the exhaust manifold. The manifold gasket needs replacing.
There are 4 studs in the manifold and 4 corresponding nuts holding the turbo charger on. The manifold - turbo charger pair are on the vehicle and one of the manifold bolts is shielded by the turbo charger. I believe the turbo charger must be removed first.
One of the 4 nuts is accessible with either a box end or crows foot, the second nut is accessible by a box end. The other 2 nuts are only accessible with an open end wrench. I am concerned if I try to loosen those last 2 with an open wrench I will round the corners of the nuts and then be really stuck.
Are there intermediate wrench types that are half way between a box end and an open end? It would have to slid on via 2 sides and then rotate to 'lock'.
I haven't tried heat. Will simply starting the engine and waiting for the manifold to get to 500 degrees or help? Or is this method band and I need to try direct heat on the nuts as best as I can?
What have I missed? I can't be the first one to run into something like this. After braking things for decades I have learned to slow down. However at this point I am well and truly stuck. (although I haven't made is worse yet.) Thanks in advance - Dan
