- Feb 7, 2016
- 172
I am looking for recommendations on a small chuck (less than 6") so I can produce and hold aluminum rings. The problem currently is the 6" chuck jaws do not have a small enough diameter to fit internally on a ring.
My 6" chuck is mounted to an adapter which threads onto the SB spindle nose.
Should I consider a 3 or 4" chuck with an adatper or consider a chuck that would directly thread onto the spindle? A pro/con comparision would help me determine the best solution.
I am currently sitting around 0.0005" run-out on SB spindle.
