- Jul 14, 2017
- 2,448
I've bought couple of small generator couple of months back and started a thread on this forum, link: https://www.hobby-machinist.com/threads/old-gasoline-generator-repairs.66014/ The smaller one is finished works as it should, but the Tecumseh HS40 powered Bosch is definitely something wrong, now the carb works as it should and the ignition seems to work right, but the entire engine and generator is shaking so much it walks at walking speed on the garage floor. Any advice what would cause so much imbalance in the engine, i've split the generator of the engine is still shaking, the flywheel key and the flywheel are both good, i've change the oil today and run the generator but it started dying after 15 min of running, it will star on the first pull again and run almost seams the fuel is shaking so much in the carb it starves. It is mounted on rubber mounts to the frame which allow it to move a lot, very strange, any advice is much appreciated
