Small Taper
drom68
Nov 13, 2013
128
Had a customer come in with a small part that needed to be made, the part has a small taper. I quickly remember a post on here on how to cut a taper using a ground tool angled, post #88 on a project of someone.
I was able to use my cut off tool and angled the QCTPt to match the taper that was needed. Worked great and thanks for the person that had posted a different way of turning a taper. :thumbzup3:
Nice work :)) If it's a precise taper, how did you set the angle?
The way i set the compound for a taper is get the taper per inch. use a dti on the compound and a dial ind. on the cariage and and adjust as needed.
