- Aug 26, 2013
- 167
Can pillow block type bearings be put directly on the shank of an E16 style extended collet?
I have seen some with locking collars recently and got a brain storm. My sewing machine motor has a small pulley on approx.1.00" dia.. I am assuming the r.p.m.'s at around 8000, so, if I double the dia. of the pulley on the shaft I should see approx. 16K r.p.m.'s, correct?, making it a 2:1 ratio.
So with that in mind, the idea is to use a 0.50" E16 extended collet as a spindle shaft mounted to two pillow 0.50" bearings, driven by the sewing machine motor. I am using mainly styrene, wax, and light density urethane mold boards. Never any metals with this configuration. Does this sound doable or am I dreaming. Comment please.
