H
Hukshawn
Forum Guest
Register Today
Made in Taiwan.
I'm fairly sure... But now I'm not so sure any more since you question.
The pulley bearing was a 207. I recieved those today. I'll put them in tonight.
The 7206 has exactly the same dimensions as your 6206 bearings so they are a direct replacement. Just search for the best deal you can find on the 7206-B-2RS-TVP bearings. This FAG bearing is a class P5 bearing and should suffice. You can find more info here: http://medias.schaeffler.com/medias/en!hp.ec.br.pr/72..-B-2RS*7206-B-XL-2RS-TVP. Be sure to click on the tabs to sort out what the different letters in the bearing designation mean.
I also discussed them and their installation here: http://www.hobby-machinist.com/threads/spindle-bearing-replacement-for-the-rf-31-mill-drill.49002/
Just a quick note for you mikey. The 6206 is a deep groove ball bearing indented to take radial load only. The 7206 although having the same envelope dimensions (OD, ID, and Width) is a ball thrust bearing. They are intended for different applications.
Right mikey, an angular ball thrust bearing or "thrust" bearing - same thing. Sometimes the 72xx series bearings can be installed as pairs in a back to back or face to face or tandem (face to back) configuration. The situation in which they are installed is determined by either the amount of thrust load to be taken up, or whether there is active or inactive thrust load. In a lathe, it should not matter as the load will likely be inwards towards the chuck. In summarizing although both a 6206 and a 7206 have the same envelope dimensions, being OD, ID and WIDTH, they are intended for a different purpose. In some cases, a 6206 and 7206 will be fitted on the same shaft. The 6206 takes up heavy radial load and the 7206 takes up thrust load.The 7206- B-2RS-TVP bearing I listed is a FAG angular contact bearing.
Sooooo, I goofed.
Refer here
http://www.hobby-machinist.com/threads/b-port-clone-rebuild.62975/page-2#post-522350
