The lathe is a 1945 South Bend 9a. The lathe is in reasonably good condition.
Currently there is a 5/8 collet in the spindle with a 5/8 rod being used as a mandrel. There is an aluminum cylinder with a 5/8 bore affixed to rod with a set screw.
I machined the cylinder to be concentric with the rod. A dial indicator reads both the rod and cylinder are circular in the horizontal to plus / minus half a thou.
However when I turn the spindle clockwise and then counter clockwise the indicator jumps about 5 thou. After the initial 'jump' the reading remains within the plus / minus half a thou. This is valid in both rotations.
I have not checked the vertical run out. Should I? Will it provide useful information?
What is causing the jump?
