Put the jam nut back on the stud and back off about one thread. Take a brass faced hammer (12 oz) and give it a good blow. The stud shaft should start to move. Back off another thread and give it a few more blows and continue until the nut comes off. By them a light tap or two with the same brass faced hammer should drop the stud off of the reverse tumbler. Repeat for the other stud gear stud. Don't beat the crap out of it! It's cast iron and can break! A small arbor press would be the best way to remove. Ken
OOPS!! Just realized the stud is turning with the jam nut. In that case, grab the stud with a pair vise grips, not very tight and see if that will hold it while trying to back off the nut. If I recall, those studs are hard on the surface, may not get a grab with vise grips. You might rig up a tool using the oiling holes to hold it while removing the nut.
