[4]
Southbend 14" 2H Lathe
[3]
[10] Like what you see?
HoustonIV
New Member
Jun 23, 2018
21
Thank you vocatexas, I have the brochures from this site, been a member since I re-conditioned my Frays all angle mill 6 years ago. The southbend manuals there were mostly engine lathes, I have a 13x60 and all manuals for these lathes. I was hoping for the actual turret information
Janderso
Jeff Anderson
H-M Platinum Supporter ($50)
Mar 26, 2018
1,140
That is one sweet lathe you have there sir.
HoustonIV
New Member
Jun 23, 2018
21
cvairwerks, Thank you, I have been following texasgunsmith for a while now and have all the parts manuals etc he has, looking for the operator's guide to assure that I do not break anything while doing the initial run to verify tolerances
markba633csi
H-M Supporter - Gold Member
Apr 30, 2015
3,174
Is that your son there grinding valves? I like the determined look on his face
Mark
markba633csi
Apr 30, 2015
3,174
Heh heh reminds me of me when I was that age
P. Waller
Mar 10, 2018
913
Do you have a product or operation that will requires such a machine?
I like turret lathes, often do several operations in an engine lathe then do the end drilling and tapping of the parts in a turret lathe, much faster way to go about it, they can not be beat for this type of manual operation. If it has a powered turret feed one may drill holes very rapidly.
brino
Jan 2, 2014
3,486
First, Welcome to the Hobby-Machinist!
Second, Do you have a model number or catalog number, for the lathe?
-brino
FOMOGO
Sep 2, 2013
1,885
Welcome to the forum, and that is a nice solid looking rig. I have several sets of those New-way carbid seat cutters. I mostly run mine with a half inch drill and an adapter I made, but have been gathering parts for a setup to use them on the Bridgeport. You might check here for turret info, just the first one that I picked. Mike
HoustonIV
New Member
Jun 23, 2018
21
I do not know why I laughed when I found out this unit was delivered to a chuck manufacturer
HoustonIV
New Member
Jun 23, 2018
21
I like the Neway tooling,, I have tinkered with an old jewler's dremel that is foot operated and allows the hands free for cutting,, I will send pictures of the next head an Isuzu diesel
HoustonIV
New Member
Jun 23, 2018
21
I do have products to manufacture, Sailing vessel sheaves out of aluminum and delrin,,, most of the rig manufactures are out of business and getting replacement sheaves is difficult
I am converting the motor to 240/3P for continuity with my Bridgeport and other tooling but hope to be up fully running in a month
P. Waller
Mar 10, 2018
913
Turret lathes are perfect for that kind of work and are simple to operate, most have a turret feed, cross slide feed and carriage feed all with stops. All that I have seen have threaded stop rods sticking out of the back of the turret, one for each position, one of the drawbacks of these machines is that you can't load long stock from the front because the turret is in the way so leave ample room behind it to back load through the spindle.
I was running this old W & S today, in order to load stock longer then about 48" I have to push it through the guide tube from the back, it is 5 1/2" thru the spindle and I face a lot of conveyor rollers and shafting with it. use a piece of aluminum or steel bar to push the parts through the guide tube and spindle. These machines are fantastic for drilling large holes shorter then the turret travel, they will easily push the stock through the chuck so keep it as tight as possible.
On this machine the blue and yellow guide tube has a rotating spider on the end and will slide along the round bar ways with a hydraulic cylinder which is handy with long heavy solid bars. To control the end of the stock in Z place a flat ended stop bar in one of the turret positions and set the turret stop, After the finished part is parted off push the the stock out until it hits the stop bar, retract the turret, rotate it and knock out the next one.
HoustonIV
New Member
Jun 23, 2018
21
Really a nice set up. I have all that it would take to set mine up this way, which would really be good for hydraulic actuator arms prior to chroming. Thank you for sharing P. Waller
HoustonIV
New Member
Jun 23, 2018
21
This is a Hall Toledo (Hall Manufacturing) In-Frame Bore Bar. No one at Hall recalls it being made,,, I was told that the Richard Petty Museum has one? any body seen this?
[6]
[5] [7]
