- Nov 14, 2016
- 3,002
I've got a belt grinder on my projects list. One of the things I've noticed is most of the plans recommend a 3 phase motor and VFD to provide speed control. Alternately many suggest a tread mill motor.
I'm wondering how useful speed control really is? Lots of quality grinders round (bench) and belt use a fixed speed. Variable speed grinders actually seem to be more common on lower end grinders making me think it is more of a marketing thing than any kind of necessity.
I can see where having a couple of speeds to cover a wide variety of materials (wood, plastic, aluminum, steel etc) might be desirable on a belt grinder, but swapping pullies or using a multi-range pully seems more economically viable, and not that big of a deal unless you swap between materials frequently. Certainly less of a hassle than doing so on a lathe, where that remains a common practice.
So do you actually use your variable speed? If you don't have variable speed do you often find yourself wishing you did?
