- Jun 12, 2014
- 4,817
You may try different belt tensions. Different thoughts on th use of link belts, anything is better that the stock belt. Many belts will take a set when stopped, and then you will get some vibration. I have been using the Gates Tri-Power which is a notched belt with good results. You will need a BX-24 and a BX-25, as the stock belt is somewhere in between the two. Single phase motor can cause a bit more finish issues for some.
