I am putting this in a seperate thread than the CNC conversion as it technicaly has nothing to do with the CNC conversion itself. Now that I have the CNC conversion done I have a couple of other issues that need attention (issues I find as I use the mill). I did ask these questions over on the PM FB page as well, so I figured I would check in with you guys also to see what you think. bascly I am having a couple of issues with the spindle on my PM833.
The first is spindle nose heat. Is is common to have to take the spindle apart and repack/retorque the bearings when new? I ran the mill for about 45 minutes at speeds varying from about 60 RPM all the way up to max RPM in 5 minute increments before putting a load on the spindle and the nose/tool holder didn't get very hot. Now that I have put a load on the mill and cut some parts she gets pretty toasty after about 10 minutes of use. I cant hold the spindle for more than a second or two before I have to let go HOT...
Second question I am using TTS style tool holders in the mill, But the collet does not go all the way up into the spindle. It is not an issue that I have seen else where on FB group or anywhere else as of yet so I am not sure what is going on, but it appears that the taper in the nose of the spindle isn't cut deep enough to let the collet go all the way in. The set screw as been adjusted and it isnt the draw bar it pulls the collet in just fine. The collet appears to registers agents the nose fully around the taper and holds the tools just fine, it is just that the collet sticks out about 3/16 inch below the nose and the TTS holders don't register agents the nose as they should. Does anyone else's collets look like they hang down lower than they should?
Thanks
Thanks
