- Jan 2, 2014
- 8,854
Question: how would I go about finding a reamer for the VN #C (Hardinge 5V) taper to use by hand if I need to clean it up?
Vanderline, I did not realize that we were talking about a somewhat less common taper.
I read somewhere recently (likely on this site!) about someone not being able to find a tapered reamer for a decent price. His solution was to find another tool with the same taper (perhaps a drill bit?) and make a cutting edges on the tapered shank and use that as his deburring tool.
Note the shank of a drill may be left softer than the cutting edge...I don't recall if some attempt was made to harden it.
This is meant more as a last-ditch method to get a tapered reamer, and really for minor deburring it could be enough.
However it sounds like investigating that pin is at the top of the list.
Please let us know how it goes.
-brino
