Square column for mill build
Shawn_Laughlin
Active Member
May 22, 2019
85
does anyone make/sale a mill column only? Dovetail or boxway z and matching slide only,no motor no x and y,only the column and slide with maybe a system to lower and raise it? Or am I doing to have to try to piece something together from a used mill? I have a grizzly g0791 mill lathe,it’s a g4003g with a round column mill and I want to convert it to a square and I’ve seen where people have done it with there rong fu but they don’t go into detail by any means. I either want to completely build a whole new stand alone machine or just use it as is now on the lathe.
Thanks
matthewsx
H-M Supporter - Silver Member
Jan 2, 2019
833
I doubt you will find anything new that will be cheaper than buying a complete machine.
Here's the one I found on craigslist that got me started down the path I'm on.
You will probably be dollars ahead to sell what you have and buy what you want, I'm only really doing this for the learning process.
Cheers,
John
Canus
Active Member
Mar 19, 2018
129
Check out Bruce Whitam. He sells a kit that may do what you want.
vinnito1
Active Member
Oct 27, 2017
25
I not aware of anyone selling a bench top mill column only. Before undertaking my column build on my G0704, I checked with Precision Matthews if they sold any of their products "unfinished" since I would not be using may of the parts for my cnc conversion process. Matt replied to me that they do not offer an unfinished cnc kit
Attached is my link to my cnc conversion and column upgrade to my G0704. If building your own column interests you, I would ask what machine tools do you have access to build it? I am luck that I have access to a Bridgeport mill and lathe to be able to make most parts. I don't know of the size capacity of your mill/lathe combo, but I spent considerable time planning on how I was going to machine/finish the parts with the tools available. In a few cases, the cuts I needed to make are bigger than the X/Y travel on the mill, so knowing how to re-indicate before machining was important.
Making your own column is not cheap either. As many people have already said, look for a used machine or find a good scrap yard. I needed a thick piece of steel that had a cross section of 3"X 4" that was ~11" long. Checking with the online and local steel suppliers, a piece of cold rolled 1018 would have cost me at least $150. A local scrap yard sold me a piece that was 2.5x3.75x11 for $20. I don;t know what flavor of steel it is ( i assume A36 hot rolled) but for $20 and checking/tweaking my design, I couldn't pass it up.
Here is the link to my build
Shawn_Laughlin
Active Member
May 22, 2019
85
Yes vinnito the prices of steel almost gave me a heart attack when I started pricing but I kinda lucked out as well. I actually build pressure vessels and have plenty of sa-516-70 steel plate at my disposal. Its not The best material but it will work just fine. I’ve git more 3/8 and 1/2” than I know what to do with.
The whole reason I bought the mill lathe combo bc I really have no room at all. I know people are going to question that but really I have not one square foot of extra room.I am a sardine in a can,really and I need my lathe so there is no way to to fit and single thing in my garage. I had to store my moms fridge recently when she moved and it’s still there and with the motorcycle it is stuffed so I have to keep the combo until I get a little more room but do plan on buying a medium size machine or even a Haas cnc mill one day,I’ve just got to get a lot more experience under my belt.
I thought about,if not already a thing, combining a box way and linear rail and make a linear box way. I have 20’ of solid heavy aluminum supported, hardened Linear rail and thought about 4 strips, 2 in the front and two in the back and build a roller assembly that is boxed in like a box way. Don’t know if it’s a good idea or not but I’ve been wanting to bounce that off some people that are more knowledgeable than me on these things. I’ll post a picture of the rails I’m talking about.
I can build anything and weld anything and very good with metal work but I’m limited to what I have at home and work (meaning machining tools) so I have to make everything withvwhat I have.
Shawn_Laughlin
Active Member
May 22, 2019
85
Astjo2, Thanks for the reply. I can find ways but no one lists the prices at all and when you fill out for a quote I hear nothing back bc I’m not a company which really pisses me off. And say I’ve got the ways in hand I’m so knew to this I’m not sure of what I would need. I could figure it out with trials,errors and money but one of those I don’t have a lot of. I’m very new to the machining world and I know no one that does that kind of work either so I’m left asking question and figuring it out and I’m good at problem solving and building but would like for it not to take years to complete and that’s why I would like to buy an assembly.
Shawn_Laughlin
Active Member
May 22, 2019
85
The only problem I see is the frame that the rail mounts to needs to be laser straight.
matthewsx
Jan 2, 2019
833
There have been many discussions on this forum about how to make a round column mill do precision work. You have what appears to be a very capable machine, if you're having trouble getting the results you want from it I would suggest trying to resolve them with your current setup before re-designing it from the ground up. It's very possible you could make the changes you're talking about and still not get the desired results. Sometimes the only solution is a larger, more rigid, more precise machine to do the job, and sometimes you can get it done by modifying the process and/or materials used.
The rail you have might be good for a surface grinder or CNC router, making it work for a vertical column would be challenging to say the least.
Post up some pictures of your shop and the projects you've worked on, or at least tell us what you're planning to do that you don't think the G0791 won't handle. It's easier to figure out how to make one part than building an entire machine, ask me how I know this....
As for storing your mom's fridge I can understand that. I recently moved a bunch of my mom's stuff into a rented storage unit so I could expand my shop. For me it's worth the extra monthly expense to be able to use my garage as a shop rather than storage for stuff that will likely never be used.
Cheers,
John
astjp2
Aug 23, 2013
950
Just to be clear I would absolutely replace the steel rail might even go with good stainless grade.
Well you need to not do the millennial thing and actually call the companies on the telephone, if online is not getting you where you need to get an answer, then call. Also stainless sucks for wear, a good carbon steel is better, much better. Stainless is normally too soft. Just think of how stainless knives do NOT hold an edge like a good Damascus (carbon) steel will. You can also align the rails by a solid block, that will get you within a few tenths.
Shawn_Laughlin
Active Member
May 22, 2019
85
6AEF8F1A-8196-45DB-B01E-D1593A2DFE91.jpegC6799EF5-7352-41D3-82BE-70E05CB6B30C.jpegThank John and astjp2 for your replies. I put my dti at different places down the column and then at the front and backside of base and found that it’s the column base itself and where it connects to lathe bed where all the flexing is coming from. It also explains why when I face or turn in that general area my measuring or different than at the sides so I’ve decided to start there.
I built a 1/2” steel cover ,that I welded together and 14 half inch bolts the secure it to the base , that I will then take a piece of 6 x 4 x thicker than your average I-beam , that will either bolt to concrete or the lathe base column cross support. The cross support is also an addition I felt it needed and it did..... I was surprised how much just skinning the column base with 1/2” plate helped so adding the I beam should really make it a lot more ridged. I think I might even add 3 tramming bolts, 1 in back and on each side, the front has no room bc of the dro I added. You have to just make the dro mount anyway you can on this machine and now I know why grizzly doesn’t offer dro pre installed or even a kit for it. Getting tge dro mounted was arguably the best thing I’ve done so far to it but that’s way off topic.
I gotta go in a second and get shorter bolts.
Shawn_Laughlin
Active Member
May 22, 2019
85
Your right astjp2, my dad bought be a Damascus skinning knife at the sturgis bike rally a few years ago and I’ve never had to sharpen it. It might be bc I haven’t got to use it much but. Lol. But I agree with you
spumco
Active Member
Jan 15, 2016
318
Not a trivial job to align 4 surfaces so they're co-planar and parallel.
I'd suggest selling the rails you have and buying some regular linear guides. Those can be attached to a big chunk of square tube, which in turn has had an adapter flange welded & machined on the bottom. Instant new column. Fill it with epoxy granite to stiffen it and damp vibrations. The rails can be aligned and bedded in epoxy so the trucks don't bind and they move perpendicular to the mounting flange.
Build a head out of plate steel, fit a spindle and motor to it, and...
Or sell your mill and buy a square column mill and save a bunch of time.
testwest
H-M Platinum Supporter ($50)
Jul 1, 2019
9
And here I am, Shawn check your PMs
Shawn_Laughlin
Active Member
May 22, 2019
85
I worked this weekend on making it more ridgid and it made a difference it the rigidity but now even though it cuts better there a little bit of shaking like when no load is put on the cutter and it’s just free spinning. I’m thinking it’s possibly the column itself so ima try the filling the column with an epoxy granite mixture to see if they cured it. I know it won’t hurt it. But I have a question. Where do you get the crushed granite? I have some granite drops that were left over from my counter I had done a while back,so could I use that and just crush it up somehow or do I need something specific?
Or is what I need easy to find?
I Have epoxy but the other materials I’m not sure what’s best bc there is so much on the internet that says one is good and another person says it’s not.
matthewsx
Jan 2, 2019
833
Decomposed granite is available at any home center store. Lots of good info on the correct mix out there.
hman
Feb 17, 2013
2,415
I don't think the exact nature of the fillers is important, as long as all of them are hard. There are lots of recipes out there on the interwebs. When I filled the column of my X2, I used a mixture of things I had on hand - included glass beads from the sand blaster, some aquarium gravel I'd bought for the project, and a goodly handful of 1 ¼" black drywall screws (to give it some "long distance" stiffness). If you use such screws, be sure they don't have an oil coating from the factory!
Not shown in the photo, but I scabbed a long rod onto the tip of the vibra-graver and used it of agitate and de-air the mix after pouring it into the column.
Shawn_Laughlin
Active Member
May 22, 2019
85
I did a little experiment and used a 1/4 cup granite blast media,about 120 grit and a 1/4 cup black aluminum oxide blast media ,about 60 grit and I mixed that with some resin until I thought it was good enough,then I mixed in the hardener and added a little more of each,resin and hardening and got a good mix.
Was surprised how heavy it was for just that little amount. I beefed up the base and added a column to the concrete and secured it to the concrete and it made a huge difference but I learned exactly what I’ve read that stiffness doesn’t mean no vibrations so the granite epoxy should make it night and day.C0C8793F-0460-4D9C-957C-AA41097FAECD.jpegD2A0E509-4860-42C9-B794-A28FB8D374CD.jpegB43EE27C-80D3-4588-BF3D-0740954F667D.jpeg25E584D7-243D-4D8A-9770-F4FBDF450E88.jpeg
Shawn_Laughlin
Active Member
May 22, 2019
85
I think ima tack a piece of flat bar on the i beam front and back and seal up the corners with caulk and fill those voids with the g epoxy.
I also lowered the mill as far it would go and marked the bottom of the mill carriage, I guess you could call it, and thought about if these mods I’m doing aren’t satisfactory then I will tack some gussets to the column, below the mark I made so I will still have full usable travel.
Other than spending a bunch of money and building a completely new steel frame or buying a new mill all together ,which I really have absolutely no room for that, this thing should be as sturdy and vibration freely as
reasonably possible. I wil most definitely keep the thread updated bc it sucks when you start reading a thread your interested in just to be let down when the thread is never finished.
matthewsx
Jan 2, 2019
833
Good to see you making what you have better:encourage:
Shawn_Laughlin
Active Member
May 22, 2019
85
I have an urgent question. So I was thinking about just drilling a 1/2 hole pour the g epoxy through a funnel and fill the base and leave the bolts in. Now after the epoxy has cured how hard do you think it’s going to be to removed the bolts if needed? I will have to remove the bolts holding the column to base so I can fill the Column and I don’t want to pour this stuff and find out the bolts aren’t coming out without an act of god. Thanks
hman
Feb 17, 2013
2,415
Trying to pour granite epoxy thru a small hole is likely to be an extreme exercise in frustration. If at all possible, you want to pour into the open end of the column - upside down if necessary. As for making bolts, etc. removable, a possible approach would be to grease the heck out of 'em before pouring the epoxy. Even better would be if you could put sleeves of some kind over the bolts. Try various sizes of PVC pipe, be sure they're a snug fit across whatever they have to span, and grease the bolts anyway, just in case any epoxy seeps in.
This article may be of help:
Shawn_Laughlin
Active Member
May 22, 2019
85
You’re right hman it was frustrating. I wasn’t prepared as well as I though. I poured through a hole I drilled in the top of the base and quickly realized the hole was too small and the first batch I didn’t get to use much of,plus I needed to remove the dro glass scale bc it got in the way. I want to say something really fast about my first batch bc I’ve seen the question before and I proved everyone wrong and some confirmed what they thought might be possible...... I used the epoxy I had laying around the house and a couple small kits I could find at hobby lobby and Lowe’s. I combined into a single batch a 4:1 epoxy I bought years ago for carbon fiber lay up and multiple 4 ounce kits of 1:1 and it cured just fine except a little fast. Also these epoxy had 3 different types of hardener speeds and 3 different chemical make-up hardeners so as long as mixed throughly it will set and cure just fine. So if in a pinch I promise it works. Now the second pour went great. I opened the hole a little bigger in the top of the base and poured till no more would go in and I just left the funnel in place. Now on mine I noticed on top of the column where the handwheel screw bracket mounts to the column there is a 3/4 inch hole that That goes straight into the hollow column so I got lucky and didn’t have to remove the column and turn it upside down but I had a problem. I looked through through this hole in the column and it looked like it stopped at the flange that mounts to the base well I was wrong. As I poured the epoxy in through the top of column it was steadily pouring out the funnel I left in the base so I wrapped a rubber glove around the funnel and stuffed paper towels and tied a crescent wrench down onto it to keep the epoxy from flowing out.After that all went well. The epoxy cured and the column is rigid as I think it could possibly be unless I welded some some gussets to the Collins which I won’t have to. Before I could barely take a light cut on aluminum without breaking an end mill and crazy vibrations. Now I went down a length of 3/8 thick aluminum 1/2 deep and cut it like butter. I also can use the side of an end mill where I couldn’t befor. Here’s some pics.4CC88EFB-559B-43C7-8ED5-D84D0A5074F5.jpeg439E109C-C7F0-4172-A00C-8AB078E96DDF.jpegC256083E-0AF6-416A-A7AE-629AE0629FEF.jpeg69D218D3-237F-4693-AA79-C6276AF1ECEF.jpeg37FCEA61-3079-4603-8015-53A0EC9A7140.jpeg7D6EDBDF-44C0-454D-970B-9F731C63071F.jpegF71B70AF-C962-4D28-A949-BDCA326A1AFE.jpeg
hman
Feb 17, 2013
2,415
Yahoo! Good news. I'm happy to hear that you were able to overcome and succeed!
matthewsx
Jan 2, 2019
833
Glad the epoxy worked out for you, no guarantee that anyone else mixing different types of epoxy will have the same results. It might not set up at all, or it might smoke and catch fire.
In my experience epoxy is best used as the manufacturer recommends. Anyone who wants to learn about it will do well to read up on what the Gougeon Brothers have to say at epoxyworks.com
Cheers,
John
