- Jun 15, 2017
- 531
I have an unusual question.
If you have a pool, you know the filter and pump parts are made of cheese. Overpriced, and designed to fail. This week I learned that the valves on my pool have incredibly flimsy grease fittings on them. They basically dissolved in chlorinated water. They fit in 1/8" NPT holes in PVC. There are knobs on them, and they're full of grease. You turn the knobs to push grease into the valves.
These parts, made by the Jandy company, are worthless. I was thinking I would just replace them with stainless zerks which only cost a few cents each.
Someone pointed out that the zerks might leak water when the pressure was on.
I'm buying a box of zerks anyway. They only cost $13 for several dozen, and they can be useful elsewhere. Is there such a thing as a stainless zerk which is made to resist internal pressure so the grease doesn't back out?
The alternative is to use NPT plugs. I can remove the plugs occasionally, put the zerks in, shoot grease in, and replace the plugs.
