I used my steady rest for the first time. My lathe was picked up second hand so the steady rest was already equipped with bearings. The bearings are USA, but two of them heated up to the point I had to stop. I made a cat head to run in the steady so I could finely dial in a rifle barrel to fit a radial muzzle brake on it. The barrel is way too short to do through the head stock. I had a heck of a time dialing in the barrel and I believe it is due to the bearings on the steady rest and overall, not a rigid set up. I was able to get within two tenths concentric to the bore and the OD after the threads were cut. It took me awhile though...as soon as I put pressure on a set screw, my Interapid moved quite a bit, but did spring back. Definitely not as precise as dialing at the headstock. This normal with a steady rest setup?
My main question is, should I replace the bearings on my steady rest with the same cam follower bearings? Or should I fit a small high precision bearing?
Here is my set up and by all means, if you have a tip or a concern with how its set up, let me know. I'm all ears in making a better setup. Pre '82 copper pennies are between the barrel and cap head. I later swapped them out with brass tipped cap heads, which seemed to help dial it in a bit...
