- Feb 23, 2012
- 43
hi all,
been trying to recondition the steady rest for my clausing lathe.. it was in bad shape.
I managed to get almost all the bolts out without breaking them thanks to loads of kroil. however, the nut that holds the clamp at the bottom snapped off..
steady rest as I received it.
I cant tell if the stud is threaded into the clamp part or press fit (looks like latter though).
my thinking is to drill out the stud and replace with a same sized bolt. then maybe epoxy the bolt to the bottom.. I don't think I will have clearance problems under the bed..
I don't have a set of reamers (yet), so I think press fit is not doable
What other options are there?
-- Roger
-- Roger
