- Apr 16, 2019
- 745
A steady rest for my little Chinese bench lathe was on my wish list since I got it a few years ago . I found some kind of fixture in the scrap dumpster at work , sand blasted it and was under the bench since . I’m waiting for parts and supplies for some other projects so I figured I would at least start and then figure out what other material will be needed . First thing I needed to make the opening as big as possible, it also wasn’t round to begin with . As always it’s a learning experience, my little boring head needed the bar in the horizontal position so the carbide tip ones that came with it wouldn’t work I need LH ones . i bought some round 12mm HSS from Amazon thinking it was harden like my square bit on my lathe . Ground a bit that I thought should work but didn’t take long to realize that yes it was hard but not hard enough to cut especially the interruptions lol Went back to see what I ordered and its air hardening , read some on heat treating but since the only thing I have is a torch set gave up on using that for now . Kept on thinking on how to use my square bits in the 12mm round hole in the boring head without damaging it. Came up with a 3/4 round holder for the square bit . Took a piece of 1/2” OD hydraulic tubing band sawed a 1/4 off the length . The bit was chamfered and works fine . For those thinking “ why not use your rotary table ?” Didn’t think of that until after getting the HSS bit working lol Once I get it opened up Ill be able to mock it up better on the lathe. You’ll notice the one picture of the set up the set screws are missing , they didn’t like the first bits vibrations lol
