Am building a Steam Donkey from Wm. Harris plans and a vertical and a horizontal engine with castings purchased from Burnzoil, a local foundry in Auburn, CA. He, Mark Bruto, does not supply plans but includes several pix. and some dimensions; bore and stroke for the kits. The dimensions for the steam chest ports are .280+.200+.290 +.200+.280. The .200 are the separations between the ports. Should the valve pocket be the sum of two adjacent ports including the space ie; .770 minus 10% =.700 be correct ? A valve casting was supplied but I wonder if bronze might be a better choice ?
