So here in Chicago yesterday we had a powerful wind storm come through. After the storm I went out for some branch cleanup. To my amazement I found my flagpole leaning. This is a commercial type of flagpole. It’s a 25’ tapered pole 4” at the base and .188 wall tubing. I had sleeved it into the ground but can’t pull out of the sleeve at this point. I was thinking of making a clamp out of a 4x4 cutting a 4” hole in the center then split the 4x4 and throw som carriage bolts in it to make a clamp at the base of the pole. Then use a 2x4 as a lever and try pulling the pole out of the sleeve like they have for fence post.
My big question is how could I take the bend out of the flagpole. The bend is gradual and honestly very minor but as you can see in the picture is enough to have to fix it. Trying to think of a way to straighten. There is about 2’ in the ground which is where it bent right at ground level. Any suggestions on how to save this pole. Cost ALOT of money and would hate to have to buy a new one. Thanks for looking
