Hello all,
So I have just finished my 3rd Stuart D10 crankshaft. Thy have all been built using the single center shaft, pinned and then cut the extra between the webs. The fit has been almost press fit(I could push the webs on the center shaft by hand firmly.) I used Loctite 603 with thorough cleaning with acetone before assembly. I let it fully cure between drilling, pinning and cutting between the webs.
The last two crankshafts have run true, but the Loctite on all of them has failed. I thought the 3rd one would finally work, as I was extra careful with gluing, but two of the joints are now loose!
I am feeling frustrated, and not sure what I am doing wrong. Should I use taper pins or a different Loctite?
Thanks in advance,
Rafael
Thanks in advance,
Rafael
