My South Bend 14-1/2 uses a 2-1/4x6 threaded spindle. I recently turned a square piece with about 11 of swing to round, which meant a lot of interrupted turning.
www.hobby-machinist.com
I used the 10” Skinner 4-jaw chuck, which I installed immediately before the project. I’ve switched back and forth between the 10” 4-jaw and the 8” Rohm 3-jaw chuck many times.
I think the interrupted cut pounded that chuck onto the spindle more tightly than it’s ever been, and now I can’t get it off.
I do not use the back gears, of course, and have never had a problem using a 2x4 locked in the chuck jaws, bearing against the ways, and a strap wrench on the spindle pulley. When that didn’t work, I tried a large dead-blow on the 2x4. Nothing. I even heated the backing plate with no effect.
My final attempt was a 4-foot 4x4 in the chuck and a 2-foot cheater pipe on the strap wrench. The strap wrench (a Titan cheapie with a 12” handle and a 1” strap) shattered.
I read stories about people unbolting the chuck from the backing plate and turning off the backing plate, and I just want to throw up. I Do Not Want To Damage The Lathe.
Any ideas?
Please, telling me that this is the reason your lathe has a cam-lock system will not solve my problem, but that’s exactly the responses to such questions I see on PM.
I gotta think people used industrial South Bend lathes for work like this in the past, and we’ve just forgotten their tricks.
Rick “shopping for a better strap wrench with a 24” handle, but worried about that bull gear lock pin” Denney
![www.hobby-machinist.com](https://www.hobby-machinist.com/styles/default/xenforo/HMLogo.png)
POTD- PROJECT OF THE DAY: What Did You Make In Your Shop Today?
If the water separator is auto draining, that is your drip leg. If you want to do more, add a 10 micron (or finer) auto draining coalescing filter after the separator! Used on Ebay, of course. Either way, that looks great! You will not be disappointed with the results. This is what is there...
Any ideas?
