- Sep 22, 2010
- 7,223
1- How about using a piece of wood, maybe a 2x4, shoved into the head and jamming the back-gear against the housing?
2- Wedge a piece of hardwood between the bull gear on the spindle and the housing to keep it from turning. The headstock casting is more than strong enough to take this stress. Make a wrench to fit over the chuck jaws as suggested with a long lever arm
3- Remove the outside jaws, put in one inside jaw, completely engaged to the periphery of the chuck. Cut a piece of hardwood long enough to fit between the single jaw when it's perpendicular(+/-) to the rear of the bed and the bed. Select the lowest speed (without back gears, obviously) in reverse. Put a rod in the tailstock that will go into the bore of the spindle to keep the chuck from dropping onto the bed or cross slide. Turn on the lathe in reverse and slip the hardwood up against the face of the chuck resting on the rear bedway. Your chuck will almost immediatly become unstuck and unthread itself. Use a device to hold and position the wood so as to prevent simultaneous removal of hand/arm members.
Any others?
Best,
Nelson
Any others?
Best,
Nelson
