Cheap they are not... That's one of the reasons I suggested a 1/2" wide wheel; they're a lot cheaper. Mainly though, 1/2" wide wheels tend to need less balance adjustment. 1" wide wheels always seem to need the most balance correction. You only need the wider wheels when you have a piece with a lot of surface area.
When you get them, hold it up by the center hole with one finger and tap it lightly with a blunt metal object. If the wheel goes thud instead of having a ring sound, be extra careful with it. I know you have a VFD on your SG so, install the wheel and start it up to about 2000 RPM, let it spin several moments then increase another 400-500 RPM etc... Make sure you wear face protection and have the guard installed. Keep your body parts out of the radial line of rotation. Don't try to dress the wheel until it's spun for at least a minute or so. If at anytime it starts to vibrate and sound like it's going to take wings and fly, kill the motor -quick. A wheel like that needs an external balancer. I've had them so bad, even that would not work. I had a wheel fly apart when I increased from 3000 to 3600 RPM...
Always test the wheel and spin for 1 minute each time you use the machine.
Ray
