Here's my finished trike, painted and assembled. Suspension works great, should have added that years ago. This is the 8th trike I've built. For the technically inclined: Weight is 19kgs wet, wheelbase 1070mm, track 780mm, camber 2 degrees, caster 2 degrees, adjustable toe in via left/right threaded link rod, seat angle 42 degrees, Pro Ackerman and centrepoint steering, lever steering, hydraulic discs, Deore cycle parts, main chassis 32mm/35x20mm x 1.5mm mild steel tube, stick welded, 20"front wheels, 700c rear wheel, 9 speed cassette, 3 speed chain ring, shifters reversed, seat shaped from 3mm aluminium, seat height 190mm, nine position adjustable rear suspension.
