- Nov 30, 2017
- 20
Hi Everyone
I have a problem with slop in my tailstock quill. I was trying to align the tailstock with the headstock with an alignment bar but the tailstock guill keeps moving. I put an indicator on the quill and with it extended to the 5 inch line there is 10 thousandths play pulling the quill toward me by hand. Pushing the quill away there is 2 to 3 thousandths. Retracted to the 2" there is 5 thousandths pulling toward me and 1 thousandths pushing away. The vertical movement up is 9 thousandths and the down is 1 thousandths.
Measuring the quill removed from the housing using calipers it does not seem out of round. The diameter is really consistent at 1.86 in the quill The bore in the housing is measuring 1.87 inches so about 10 thousandths larger than the quill. Would the quill or tailstock housing be worn? I don't have any data on the bore size of the tailstock?
Thanks
Dan
Thanks
Dan
