For some time I have wanted to change the tailstock locking system on my 10” SB.
Except for threading, and without a DRO, my compound rest is often at the 90 degree position to get those small accurate distances for turning, parting, etc. Add a situation where you want tailstock in close for support it becomes difficult to get the wrench in to tighten or loosen the locking nut, and you can’t use the compound handle with the wrench in place. Maybe others have noticed this same issue.
I thought a solution was possible so made the parts necessary for a lever and cam operated locking system. The original lock used a 1/2”-13 centre bolt and needed 1/4 of a turn to operate (.019” tightening movement). I turned a .032” offset on the cross pin which through the lifting yoke, gives the same effect. I also kept the locking handle in close to the tailstock which gives good compound dial/handle clearance at max cross-slide where the base of the compound hits the tailstock casting. Everything fit nicely into the tailstock cavity and the only modification necessary was to drill two 1/4” holes up from the bottom at the rear of the boss to hold the device in place.
Already feels normal.
Hope some of you find this interesting.
