Hi Joe,
I managed to sneak away for a week over Thanksgiving. I'm glad to see that you were able to get the head apart and back together.
How is does the ring-gear drive the spindle? (I don't see a keyway in the spindle.) I'm very curious about the details of how the ring-gear is adjusted and held in place. Do you have any photos? How did you adjust the backlash of the ring-gear when you put it back?
What you have are
plain bearings (as opposed to ball or roller bearings) and I would guess that they are made of some sort of bronze. What are you using for grease? You need to be careful about what grease you use, because a typical EP (extreme pressure) automotive grease has additives that can attack alloys like bronze that contain copper. Some information on grease can be found here:
http://wiki.vintagemachinery.org/Greases and Lubrication.ashx
The front bearing is tapered so that you can take out the play by tightening the rear collar. If the rear bearing gets too loose, you can bore the bearing sleeve out with a suitable boring bar, held between centers. Then a new bearing sleeve is pressed in and bored/honed to size. I would probably send that sort of work out to a shop that specializes in that sort of thing rather than try it myself.
As far as the C adapter in the spindle is concerned, it's probably cemented into the spindle by rust and dried lubricants. Penetrating oil (a 50:50 mix of acetone and automatic transmission fluid works very well), heat and patience are your main tools. Tapers seem to come out more easily if you can pull on the large end rather than push on the small end. It might be possible to make up a pair of wedges to fit between the lip on the adapter and the nose of the spindle, similar to a pair of
jacobs taper removal wedges. If you can clean up the threads on the adapter you could make up a nut that you could tighten against the nose of the spindle to pull the adapter out. Be prepared to spend multiple sessions applying penetrating oil and tightening the puller, perhaps heating the spindle with a heat gun, and taping on the back of the adapter with a soft-faced drift. If you keep doing that day after day, a few minutes a day, it will eventually release.
Cal
